Fixture Profile for Cameo FLAT PRO 600 IP67
Just wondering if anyone has a profile for the Cameo Flat Pro Flood 600? Or can ETC create a profile for this fixture??
I have copied a link to the fixture product manual hopefully someone is able to help.
images.static-thomann.de/.../385952_flat_pro_flood_600_en_de_fr_es_pl_it.pdf
Thanks in advance
  • In 6 channel mode  the generic  LED RGBWAUv should match it
    In 9 channel mode you could use a copy of the generic  LED ISRGBWAUv but you would need to edit the profile and add one to each of the dmx numbers for the RGBWAUv channels as the fixture is a little unusual in that its third parameter is the strobe flash duration. So the others need to be shifted down by 1.  (You could then assign dmx 3 to something so you could control the flash duration)
  • Hello,
    It appears this fixture is already in the library as Flat Pro Flood 600.  Please make sure you are running the latest software update on your console. The latest software is v2.7.3.
    Thank you,
    Sasha Aranow
