SpaceBar Go Enable / Disable Macro
Hi All,
Had a quick search but couldn't find anything. I have an Nomad as backup I would like to lock out the Spacebar Go as part of my show start routine via a macro.
I've made two Macros, set as background, which contains the command "Spacebar_Go". I added an "Enable" and Disable" but this doesn't function as I'd expect. Both macros work, but both of them act as a toggle. I'd like to make it a firm "Enable" or "Disable" choice, as you'd get with a park macro or similar.
Am I missing something obvious ?
James
