B-EYE K20 fixture library issue
I got a problem when I using Clay Paky B-EYE K20.
In ML  control interface if you using "DIMMER CURVE" cause a problem.
First problem is there will be a tiny intensity fresh when I touch ML control "DIMMER Curve"
And next problem, If I active the curve 2 for example, then the fixture will stay on that curve.
I cann't change other curve at later cue even fixture value say it's different curve.
I  check B-EYE K20 DMX chart and ETC library seem not compliance.
B-EYE In ML Control the "Dimmer Curve" seem much more of mode function not a immediate feedback.
My question is if that "Dimmer Curve"  classify as mode function, then it show ""Dimmer Curve" in ML interface,it will confuse user in programming.
Anyone have similar experience or advice?
Vincent
2018.9.7
