Hey all, how do I trace in Blind on an Ion? It isn’t showing up in the soft keys. 2.7.3
hm, it does show up in nomad. if you have an external keyboard you could try J as a hotkey for Trace.
I’ll try that! Thanks! I suppose this might be a 2.7.3 bug on the Ion?
if the syntax is correct it should show up. if not i guess you found a bug.
On Ion, the Trace key is a softkey that only paints when the Update key has been posted to the command line. It's on the second page (More SK).
Hello,
Bug still present it seems. Working on eos Ti, tracking in blind is possible tracing not why ? Could be useful when cleaning a cuelist
this post was specific about the Ion classic where Trace is a softkey that didn't show up when in Blind. since you're on a Ti that has a Trace hardkey this seems to be a different issue.
Just checking if you found a solution or if this is still something you want us to look into. Thank you.
