ETC ION sneaking CS Spot
I just deleted my cues which had color and intensity values and then went to cue out and all good. But then I tried sneak enter and the values that were in the deleted cue came back. Am I wrong in thinking that since there are no cues, subs, etc. existing that those values should go away and everything be back in it's home state?
  • You are correct, when there is no other data, Sneak should return your selection to its home values.
    I tried mocking this up on my end and was not able to replicate the issue.
    I was in a cue, then deleted the cue. After deleting the cue, the values remained. I did Go To Cue Out which faded intensity out, THEN faded NPs to their home values. After the NPs reached their home values, I tried Sneak Enter and nothing happened to them.
