[Bug] Recording a group of cells in reverse fails
Hi All,
So I have two Nexus 4x4 MC's patched (48Ch) in my show (71 & 72). I'm trying to record a group in order of the outer edge for FX usage, however it fails to record the cells that are in reverse. So my current syntax is:
71.1 thru 71.4 + 71.8 + 71.12 + 71.16 thru 71.13 + 71.9 + 71.5 record group 8022
This results in the group, 8022, being created with cells 1>4, 8,  12, 9, 5. The reverse order section (16 thru 13) is being stripped from the selection when its recorded, so the group is missing the top line, making a U instead of the box.
I have also just thrown together a new show file (Attached), with just these two fixtures patched. I have Tab 1 in selected, and when entering the command, cells 16 thru 13 are never selected. Attempting to create the group in Blind, adding each cell or selection of cells individually, results in an error ("Channel List Is Empty") when I enter:
+ 71.16 thru 71.13
However if I do:
+ 71.13 thru 71.16 Offset Reverse
It works fine. Seems the error is only when specifying reverse order manually. Another work around is to enter the reverse range as individual cells. Both of these result in the cells being listed correctly in the groups list (Ie in reverse order).
I attempted to attach the show file but kept getting errors (Probably the Digs Wifi), so I have attached a link to the file in Dropbox. Group 8022 is the group created after using the first command line with the cells in reverse selection. Group 8023 is what should be created by the command line.
Showfile: Dropbox
Tested in:
Nomad for Mac, V2.7.3
Ion running V2.7.3
