I have a problem need help
As I am not a full time user of the desk, maybe I am missing something, but I don't know - I thought  I would turn to the collected wisdom here.
If I have multiple submasters up controlling channel levels, and want to know when submaster is controlling the level of a particular channel, what would be the best way of getting that information.  I have tried both About channel - there looks to be a perfect place to put that information in the source field but it isn't there - and {query is in sub} but as soon as I hit the sub button, it clears out the query.
Is it possible to have a slider that is set up as a playback act as an intensity master for that cue stack?  i.e.  If I run cue 1 in that cue list with the fader lowered, all the nip's go to their assigned locations, but the intensities do not come up until I raise that particular fader.  I would like it so that if I chose to, I could set that fader as some sort of 'intensity master' whereby I could grab that fader and lower it and all the intensities would then go out.  Does that make sense to anyone?
any help that you guys can give me would be most helpful.  Thanks!
