How do i go from Q2Q and move lights without having any light follow...I know this is beginner level, but I need help
thank you
Greg
thank you
Greg
If I understand what you're asking: With the console in Tracking Mode, make use of the Block (hard key) and Mark (soft key) attributes. If you Mark a look in the previous Cue, it will just "Fade up" on stage without seeing all the lights move into position during your cue's fade time. Block will stop parameters from tracking into the subsequent cue.
Thank you. I was struggling with that
