Recording Presets, shutter closes every time
 Hi everyone,
Right now I'm recording presets for a show.
I record them like this: "channel number" focus beam record onlye preset "number" and for updating I say "channel" focus beam update preset "number".
Everything is fine, but by recalling them from a presets some lamps do not open the shutter, which sucks. In my home preset the shutters are all open. I have some Mac Viper Profiles, Varil Ite 1100 an also Mac 2000.The same for when I recall a channel from another one the is closed then.
In all the cases I haven't touched the shutter because it´s already open in the home preset.
Of course I tried it with sneak sneak go to cue out.
It's my first big theater show an the gio and I'm little bit confused.
Am I missing something?
Thanks in advance
Kind regards
Marc
  • Hello, Marc:
    What is in the tombstone for your shutters when this occurs?  Does it show the preset as it's reference or some other source?  Can you take a look in ABOUT and see what is controlling that parameter?
    If it is the preset, then you can remove the data in blind.  [Blind][Preset][x][Enter[. Chan [y][Thru][z]{Parameters desired}[At][Enter] will remove the data.  Once it has been recorded in it will stay unless you use this method and remove it.
    Thank you,
    Sasha Aranow
