Putting Times on Submasters
Hello,
I have put times on some of my "stock look" subs (love this feature, makes busking really easy). How come the motorized fader doesn’t move with the sub?
Also, could the virtual control for sub masters also have an option under the direct selects? I hate having to close the direct select module, then go into virtual controls and bring up the submaster module.
-CTR
  • Would a macro be a possible shortcut to access the virtual subs?  If your using EOS (not ION) you should be able to use snapshots to do this as well.
    You should then be able to access snapshots / macros via the direct selects
    [edited by: BrentFJ at 11:18 PM (GMT -6) on Mon, Dec 01 2008]
  • Hey Brent,
    Yeah, that would work. Not sure why I didn't think of that seeing as the students think I'm crazy for making them write macros they don't ever think they will use. Will do that first chance I get to see if it is going to work to fit my needs.
    I suppose a snapshot would work as well. I just don't like snapshots.
    -CTR
