i explain
blind mode
i have in this cue cue 4 channel 1thru 4 at 80
i want remove all or 1 channel i do ch1 out but there is 0 value
isthere a way to have no value on this channel
like a gotocue out in live
thanks for reply
i explain
blind mode
thanks for reply
it's not quite clear what you want. do you want to remove a channel from the complete cuelist? or do you want that starting in a certain cue the channel is not part of that cuelist anymore? the question is what your scenario is. why do you want to do that? the answer to your question depends on what you want to do.
the solution is either At Enter or the Release softkey
You Know like a c chanel on Cobalt
or 3clear on ma
What Ueli said: To get rid of a channel value in a Cue (or Sub or Preset or....) in Blind, just type "Channel 1 @ Enter" (no value between @ and Enter means remove).
Just as a sidenote: this is different from 3x Clear on MA because there are no manual (or MA "Programmer") values in Blind in Eos. It is an editing mode so everything gets entered right away.
Cheers :)
