I've got 2 ETC Net 3 RFR remotes, 1 of which is a year old. the new one recently started power cycling continually when booting up. It will find the console (ever so briefly) and then the screen blanks and the top line lights up with the normal power up text.
I've given it a light shake or gentle spanking, and then it cycles up and connects normally when the switch is next turned on.
it's different than when it can't find the base station, and keeps searching for that (that I've seen).
I'm considering inserting new rechargeable batteries to see if that works. any other things to consider?
Andrew
