Is it possible to have fixed split colour on a MAC ENTOUR 350? I am able to scroll continuously, but not have it fixed between 2 colours.
Thank you!
Thank you!
If you edit the profile so that the color select is not set to snap, are you able to do split color at that time? What about if you hold down SHIFT while moving the encoder?
Hello,
holding SHIFT did the trick! Thank you so much :)
