Hi Everyone.
Bit confused here. Using an ETC Gio, and in one cue, there is an initial fade over 2:30. It is through a relatively long scene, and basically we wanted the lighting to reduce to lower levels as the scene progresses. The time is never exactly 2:30 and we have to go to the next cue which is basically a black out. The only issue is, the lights used in the previous cue continue to fade out.
Basically, I want to know if there is anyway of cancelling the fade in the previous cue and just snapping to the next one when I press Go?
Cheers.
