Hello, I have a load of generics patched as multi-cell fixtures (for a good reason..) along with some units that are patched as normal dimmers, I'm looking to run an effect across both the "normal" fixtures and the multi-cell ones. If I type: 103 through 106 [cells only] + 101 + 102 enter it accepts the command but doesn't select 101+102, I can add the effect by using two commands. I feel this is a bug.
Richard
