Control of Relay on Ion by submaster
I was trying to setup for customer submaster to control relay on Ion and have succeed only particularly. Original idea was to close contact with activation of submaster and open it with deactivation of submaster. This I was unable to setup.
I was able to add to submaster execute relay 1 on, then change the submaster to I-master. This activate the relay with activation of submaster, but to deactivate it I must use another submaster or cue with execute relay 1 off action.
When I add to same submaster both execute relay 1 on and execute relay 1 off, it will create short pulse on relay when is submaster activated.
But to I was not able to get submaster working with relay as described above to be activated and deactivated with submaster movement.
Regards Karel
