Hi all,
I currently use the Nomad/ Ion Xe and am playing about with effects.
I'm trying to get an intensity chase between 6 fixtures (USR,USL offSL, DSL, DSR, offSR, all focused to centre stage) to get a sort of spinning effect around the stage. A bit more of an idea:
cue 1: fixtures going from 0-100 repeatedly (Grouping 3, cycle time 1) for 5 seconds
cue 2: fixtures going from 0-100 repeatedly as above, however speeding up the rate to a cycle time of 0.1s over 5s
cue 3: fixtures remaining at cycle time of 0.1s, however all going to full over 2 seconds
cue 4: all out.
Each cue should also auto advance.
I've tried using subs to increase the rate as it progresses but haven't had much luck! Any advice on how you'd do it would be greatly appreciated!
