Have just upgraded my Ion Xe20 to 2.8 and the 'update HS Face Panel' warning has reappeared.
Uhm, and have you tried to actually do the update?
There is no update on the ETC site - this message used to appear in a previous software release. Forum answers at the time said that it was not updateable in the field and that the message would be dealt with in a future update. This happened - but with the latest release (2.8) the message has reappeared.
The forum said that Element classics were not updatable in the field...
You don't need to download anything as the installer already dropped the file on your harddrive. You just need to follow the instructions in the release notes that say go to Shell, settings, maintenance and use Firmware Update to update
Thanks ueliriegg, I should learn to read things more thoroughly. All fixed.
