This is for the Ion 1.4.2 (I just upgraded, so some of this may be moot).
Auto-Blocks: great concept, but the show we just programmed was programmed in a somewhat haphazard method. By opening, almost every cue had an auto-block. I want to keep the ability for auto-blocks, but is there either any way to refine this feature, or to clear the auto-block from selected cues?
Encoder wheels: what do users feel are the best settings? I played a bit with them, but I'd spin the wheel and either jump wayyyyy to far, or it would barely move. (this was with an I-cue and some gobo rotators)
Level wheel: how do you switch it to proportional? right now, if 2 channels are at 25% adn 50%, and I roll them down, then ch 1 goes out first, while ch 2 keeps rolling until it hits 0. How do I change this so they both hit 0 at the same time? (this occurs on 1.4.3 as well)
Park button: with a channel parked, sometime the LED on the button is lit, adn sometimes not. If I run a macro to restore the Parked channel, the LED lights up. Its as if the console doesn't recognize it has a parked channel, even when the lights are at the correct intensity, and the Park Park screen shows the parked channel. Thoughts?
Capture: I'm not clear as to when you might use this feature. Could someone give me some scenarios or advantages?
Thanks very much.
