just getting acquainted with the MC function but one thing i noticed on an Astera profile is that when you change values on the "master" parameter (ie- channel 301) in the ML controls window (which is virtual i believe and should modify all of the imbedded cells?) there are no numeric values displayed in the window. when you enter individual cells channels, ie- 301.1, the numbers are there.
is there an easy/efficient way to reference values for both? i will use multicell control at times but mostly want to control the whole fixture.
please advise, thanks
