Can anyone point me in the right direction of a supported touch screen to work with the ion xe20
Many thanks
Many thanks
since that guideline is not really up to date: you can use every touchscreen that says "Windows 7 compatible" (higher windows versions should work as well). the Xe has DisplayPort connectors, but with active (!) adapters you can use any other display connector as well. do not use monitors that do graphics and touch through one USB cable.
Here is a slightly more up to date version of the linked article: support.etcconnect.com/.../Touchscreen_Monitors
