In Patch Channel, when trying to swap a channel with more than one part with another channel with only one part, part one of the first channel gets deleted and no data gets added to the intended target. This means that after the swap, the address is lost unless Undo is used.
While I understand that swapping a multipart channel with a single part channel could cause unintentional issues, I think that deleting the address is unintended behavior.
Thank you!
