Is it possible to add the functionality to use the 'Text' field with the tab shape object? Currently the text field can only be used with the button objects. Having to add text boxes on top of objects is an inefficient way of labeling - for example if you want to label objects that are executing a command or are being used to navigate to various magic sheet views that can't be labeled.
Let me know if you need additional information or clarification.
