Effects on the Ion
The other day, I was working with some effects on an Ion and I came across these questions:
Is there a way to start/stop more than one effect simutaneously?
How do I stop all effects at once?  I thought [Effect @ Enter] would be the same as [Stop Effect Enter] on the EOS, but alas.
Also, I belive I came across a glitch of sorts- I had step-based effect X running, I would go into the editor and change something in any of the step cells.  Back in Live, when I would try to stop the effect by going [Effect @ Enter], (which stops only the last selected effect?), it would put the previously edited step number on the command line, resulting in a syntax error.  Then, after I would clear the command line, it would require me to add the Effect number to the command in order to get it to stop.  Harmless, but a little annoying if you have 6 or 8 nonsequencial effects running.
