Feature Requests
Another round of requests:
-When you hit enter on and Undo, close the undo screen.
-Have an undo/redo button on the Command History tab.
-Add a Move Flexi that shows only channels that are moving.
-Have an option to control if a user's changes get updated by another user. When someone is bringing channels up with an app, I don't want the programmer's updates to update the app's changes.
-Be able to change the fader page displayed on the fader ribbon on the PSD tabe by going up in number, not just down. Maybe add a "Select Page" option in the tab menu?
-Add a Fader Page select option in the tab menu options for the PSD.
-Be able to click and drag tabs.
-"Delete X Thru" doesn't work if there is no "X". It should work even if there is no "X".
-Live tab should move by page like Expression did, not by selection. Maybe if scroll lock is enabled, then have it move with selection? It's frustrating having the channels show up in different locations on the screen. It's also frustrating that even if there are fewer channels than can fit on the page, it's possible for the screen to only show a fraction of them.
-Have an option in Setup to make "Recall From Absolute" the default.
