I am unsure if the following behaviour is a bug, however it seems counter-intuitive to me, so wanted to ask the forum for some help. If I carry out the following sequence:
- Record an unmodified Effect X in Cue 1
- Modify the Effect grouping in Live and Record Cue 2 (leaving me with an asterisk next to Effect X in the PSD)
- Cue 1 Copy To Cue 3 Q-Only (leaving me WITHOUT an asterisk next to Effect X in the PSD)
I am left with the modified Effect grouping from Cue 2 tracking into Cue 3, even though I have copied Cue 1 Q-Only. I am aware that the Grouping information in Cue 1 is shown in grey when you click Effect in Cue 1, and this is probably why the value is tracking from Cue 2 when I copy Cue 1 to Cue 3. However, I can’t find a way to, for example, make the grouping information Manual in Cue 1 so I can copy it without worrying about this tracking behaviour. Thank you.
Running V2.8.2 and have tried this on both an Ion Classic and Nomad.
**EDIT: Also, if I remove Effect X from Cue 3, update Cue 3, and then put Effect X back into Cue 3 and update, Effect X now has the grouping information tracking from Cue 2, but this time there IS an asterisk next to Effect X.
