Hej there guys and gals,
I´m wondering about a few behaviors:
1. Where I´m working right now the LD get´s the Backup-Console to his desk during the rehearsals (partly programming, partly as channel/PSD-Monitor. That´s why we put it out there and back into the booth on a daily basis. That means it´s physically removed from the network and the power supply. I wanted to be able to power it up from the main-desk. For this to work both consoles must get powered up manually once after getting them back to power and network. From now on the Backup will react to the remote startup but only until it get´s unplugged again.
Is that the expected behaviour?
It´s a GIO and a Win7 ION running 2.8.2 connected through a managed switch (D-link Web Smart Switch DGS-1210-10p). Can the managed switch be the problem here?
I didn´t set up the network and didn´t check the settings of the switch so far.
2. In this venue they arranged the power supplies for the Moving Lights as a second part with the parameter "MasterIntensity". When I press @_@ with one of those guys selected it won´t bring it´s intensity to full (Level is configured as 100%) but write MasInt to the commandline (selection stays intact). Is this the behaviour for a reason? And is it possible to configure what @@ is doing?
3. Third and last is a strange one. My LD wanted to mix RGBW colors via faderwing so I configured a couple of faders for him. Then he was wondering why he can´t flash the single colors with them when in a cue and I explained that not both behaviors will work correctly in the same sub and I have to give him a second set of faders.
He sat on a universal faderwing and wanted to have the flash-subs where the mixing ones had been. I wanted to keep my subs in order and moved the mixing ones to another range I thought has had nothing in at that time (there were empty subs, I created 1 thru 40 in the beginning). Here I made a mistake the range I moved them to has not been empty but some conventionals in them (26 thru 30). I didn´t recognize that at the time. Next thing I did was creating new Subs (36 thru 40) and edited them in blind to flash the LED colors.
When we tried them they flashed the conventionals from sub 26 to 30 with them. That´s strange isn´t it?
An additional info could be that i never deleted the assignment of sub 36 thru 40 to faders 36 to 40 (even if the subs didn´t exist after I moved them in the first place).
Can that be the reason for the strange behaviour? Haven´ t had the time yet to recreate...
Thanks for your attention and I hope I could make myself clear.
Cheers Paule
