I was playing with Highlight RemDim and had a slight issue.... My houselights which are in an exempt from everything cuelist, were RemDimmed when I went into Highlight.
Is there a way to exempt CueLists and Submasters from Highlight RemDim?
subs are always exempt from highlight remdim.
you can protect channels against highlight in Patch > Attributes > GM Exempt.
and instead of putting a number in the Highlight RemDim field in patch you can put a preset. and all the channels that don't have any value in this preset will be ignored by highlight remdim
I thought Exempting the CueList would do the trick. It did not. but exempting each Channel works like a charm.
