Robe Spiider parameters control.
I've been trying to control the two outer rings individually without using the preset macro.i patched it to M1 available in the library and change it to RGBW mode in lamp controls.
1) Only preset Macros are available which are in running effects and i can't control individual rings to change colour in static.These are for both the outer rings and the single  center led.
2) Is there a multicell patch for robe spiider
3) if there isn't,how do i go about in controlling each channel in the mode.
Please advice.
Thank you.
