How do you set the channels to the level of the previous cue used, but can't remember which cue it is??
I was hoping for a single line of syntax rather than having to scroll through in Blind. Would I be able to use the Query function??
From Live, [channel n] [at] [enter] - will remove the current move instruction and set the channel value to that of the immediately preceding numeric cue. You then need to record or update the change. This applies to the entire channel, so if you want to remove the instruction of only certain parameters or categories, you can do that via the command line, by specifying (or excluding via -) what you want (or don't want).
Hope this helps!!
a
Ah yes of course, how silly of me.
Thankyou.
Well, that can be a hard syntax to remember at first. You can also: [channel list] [recall from] [last] [enter]
a
