Channel 7 is getting a current value from Q2/3. Its background value is from Cue 1/23.
I give it a manual value of 80.
When I hit [Update], it tries to update into Cue 1/23.
It's owned by Cue 2/3, right?
So it should update into Cue 2/3, right?
If you hold about and press cue what does the channel display? If you do this in live table you can see what each parameter is owned by. If it is getting it's value from Q2/3 then it should update into that cue. If it is just an intensity channel then the current level is from it's current "owner" If it is a multi parameter fixture then it can be owned by multiple cue lists at the same time and only those attributes that have values in each cue list will be owned by that list.
According to About&Cue, Channel 7 is owned by Cue 1/23.
Actually:
Before providing a manual value, Channel 7 is owned by Cue 2/3.
After providing the manual value, Channel 7 is owned by Cue 1/23.
If I sneak the manual value, Channel 7 goes back to being owned by Cue 2/3.
Channel 7 is recorded at full in 2/3 and 1/23 if that means anything.
So the manual level causes it to change ownership. I'm going to post this as a bug.
