goto cue 0 and +\-%
questions for EOS
when i push the dedicated "Goto Cue 0" button, it doesn't
also...
I've changed the level up/down percentage from the default of 10% to 5% but when I use the button it still reads +/-10% on the command line.
  • Hi there.... you need to tell it what fader you want to initiate a go to cue zero on.  So, you hold that button down and press the load button for the fader with the desired cue list.    That function is simply a shortcut.   If your selected cue is 12/4, but you want to do a go to cue zero on list 3, you have to [Go to Cue] [3] [/] [0] [Enter] from the command line.  This is just another way to go about it with less keystrokes.
    +%..... yes, that's something on the list to clean up.  Know that it IS using your default values.
    Thanks much!  Hope this helps.
    A
