Hi, all. I'm a relative noob when it comes to effects and I'm having trouble figuring this one out. Our cyc is lit by (4) 12-unit tungsten multipars, each split into (3) channels by color. So I have channels 151-154 for R, 161-164 for G, and 171-174 for blue. I can achieve white-ish by mixing RGB, with R slightly lower. What I want to do is end up with white across the whole, but march one blue channel across.
I've got blue marching across with a step effect that fades in and out channels 174 thru 171 sequentially, but to achieve white over the rest at the same time is giving me a headache. I've been considering whether I can use intensity palettes, or three steps to set blue fade in on the one channel, red to one intensity on the other three, blue-green to another int on the other three, but what I really need to do is transition from white to blue on the one channel that's marching, which effectively means have all channels up but sequentially fade out RG on one section so that only blue is left, then bring them back up as blue moves to the next section, etc.
What's the best way to get there? Thanks for any pointers.
Abe
