Has anyone been having issues with the rpu not wanting to sync with the console?
Sandi, is this seen on the initial connection or is the RPU dropping offline? You shouldn't be having a problem with this. Can you please contact tech support so they can help figure out what's happening?
thanks,
a
A-
Talked to Shaun at tech support yesterday. The console is set up as master, the RPU as back-up. On the RPU, we found that the windows shell was conflicting with the EOS shell when creating an IP address. We had to log off the EOS shell and go into the windows shell and into the control panel to network settings and create our own IP address. All is working fine now.
