Need help with a specific effect
Several fixtures need to have several intensity values.
Those Values are set by a submaster (relatively to each other).
An effect should run that fade the fixtures 30% down in relation to their current background value, set by the submaster.
I tried to use an absolute effect, but i can only use absolute (hence the name... ;) intensity values vs the background value. I would Need a @-30 in the value tab...
But even the effect with absolute values vs the Background value didn´t work when using a submaster to set the Background value. It simply didn´t recognize the intensity values set by the Sub as Background Levels. It uses Background 0 instead.
