Copying a channel in a range of cues
How do I use the [COPY TO] command to copy a channel from one range of cues to another range of cues? I want channel 144's intensity, and all timings (cue and attribute - the cues contain live I-Cue moves) to be copied from cues 43 - 44 to 80 - 82.
[edited by: E221b at 6:12 PM (GMT -6) on Sun, Feb 1 2009]
  • In the current software, both copy to and recall from take only the level information.  The instruction does not take discrete timing or effects, etc. that might be applied to the channel.   This changes in 1.5, where these functions take the entire state of the channel.  We've added a "levels only" softkey, so if you want just the level data and none of the channel attributes.
    Hope that helps - for now.
    a
  • I found your post and thought I might tag another thought onto it.  I'd like to copy a bunch of channel intensities to mutlitple cues..IE. chan 1 thru 5 copy to cue 10 thru 15.  Is something like that possible?
    Shawn
  • In blind you can select a range of cues and then set levels in them all together.  With that you can select a range of cues and a range of channels in those cues and then recall their levels from a cue or other source.
    ex: blind.  cue 1 thru 5 enter.  chan  5 thru 10 recall from cue 101 enter.  This would recall the levels of each channel from cue 101 and put that level in cues 1 through 5
