Blind Active Channel list
Hi all.
I have just made myself look a bit of a plum in front of an LD by getting confused when editing a part cue in blind.
Part 1 should have had a channel going up
Part 2 should have had several channels going out.
The LD wanted to know which channels were in which part. As the channels were spaced numerically  far apart I used the Flexi button to see only Active channels on a single screen.  However as Part 1 only contained null data for the channels going out, those channels did not appear on the screen. This made it very confusing as I could not see clearly which channels in green had gone out.
Is this something that can be rectified, or should I be more disciplined in my programming and have channels going out in Part 1, instead??
Thankyou once again.
