Changing discreet timing on a bunch of channels
I like using discreet timing on channels.  One problem I’ve run into though, is when I have a complex selection of channels and I decide to change the time on those channels.  If it’s a part cue, I can easily change the time of the part.  If I run the cue and immediately want to change the time on those channels I can use Select Last.  On EOS I can query to get all channels with  a certain time.  On ION, though, there’s no query.  I thought I could do something like CUE # TIME 3 Replace With TIME 5 so that every channel with a time of 3 would become a time of 5.  Replace With doesn’t seem to work with TIME.  Does anybody know if it’s possible to change discreet times on channels with Replace With?
