I have borrowed a programming wing so expected everything to be like an Ion. The Go, Stop/Pause buttons and the 4 encoders don't work. How can I fix this? My Nomad dongle is in my PC, not the wing. Is that a problem?
The problem is that your wing is missing a bit of firmware. Simplest thing is contacting ETC hotline so they can run you through solving the problem
Thanks will do.
Unrelated question. How do I get DS colour swatches to match chosen colours? I'm using Lee gel references.
What's not working? Post a screenshot of what you're seeing and of what you're expecting
Right-Click on the DS Tab and in the Dialogue window, there is a Tick-Box that says: "Use Colour Swatch".
Enable that.
The swatch colours should match the basic colour, but are not supposed to be exact matches.
(All red gel colours will be the same DS primary red colour.)
