Hello, I'm a relatively new user, please bear with me.
I am creating a number of movement effects which I intend to place on submasters for busking purposes in the future.
I've been building these moves using focus palettes in an absolute effect.
The issue I'm having is that the fixtures always move very slow between these positions. Reducing the cycle time results in the effect speeding up but not completing its full range of movement. For instance, I make an effect that has two fixtures start vertical, move across stage so the beams crossed each other and then back again. Reducing the cycle time would result in the lights rapidly reaching 1/3 across the stage and back again without moving far enough to actually cross over.
Recording this effect to a sub, I can use the fader config tab to make a second fader control the effect's rate. However, I can only make the effect happen even slower, the highest value being the original speed and as I bring the fader down, the effect slows.
Any help on how to rectify this problem would be appreciated. I feel I have missed something along the way
Luke
