Hello i have an ION XE, i cant find the load button in the console, how can i load a cue
thanks
thanks
For master playback (double fader): press the Master button above the double Faders.
If Xe20 and it's about the faders there: there is no load button for the faderwing, instead press both buttons below the fader at the same time
Hello thanks for your answe but i have another question
in the ion console i have a load button next to black out button and next to the option button i dont remeber the name, in ionxe for example im in cue 1 but i neee to load cue 20 i just write cue 20 and press master button? The master button load cue 20
thanks
Correct. Old Load, new Master. Does the same thing, i.e. load the cue into pending
Thanks for you answer
another question under master button are 2 faders those fader can be mapped or how can i use that fader, the ion xe have two wheels the right wheel is for intens and the left wheel i dont know how can i use it or which are the function
thanks
And If you want to assign a cue list to a fader or master pair rather then a single cue from the active cue list, you can press CUE 1 / MASTER for cue list 1.
