I have done two shows where we had the City Theatrical Wireless Dimmers and the ION/Eos RFU. The RFU wouldn't work when the wireless dimming system was turned on. Does anyone know a work-around without turning one of the devices off?
In my experience the City Theatrical wireless DMX systems stomp on almost all other 2.4Ghz wireless systems. I have come across systems that could not have a wireless access point or wireless RFU working with them. I don't know of any work around at this time. The City Theatrical boxes are very reliable within themselves but can cause pure havoc among other wireless systems.
Andrew Webberley
Hello Marty-
Is this the WDS or the SHoW DMX system?
-luke-
The ShowDMX system can be reconfigured to use a smaller part of the 2.4GHz spectrum.
By default it stamps on the entire band and shuts down everything else in it. You should always squash it into the smallest space that it still works well in.
If you have equipment to 'sniff' and look at the usage of the 2.4GHz band you should be able to find a suitable range to move it to, otherwise it's a case of trial and error.
I'd suggest trying something like this:
That should usually give you reasonable wireless, hopefully without stamping on other users of the spectrum.
The key thing to remember is that 2.4GHz is licence-free. This means that everyone and their dog is using it (even Starbucks!) - you cannot consider it to be yours, and you can't expect the band to stay clear.
The other side of the coin is that you should be nice to other users. Don't configure your systems to swamp the whole band.
The default whole-band setting of ShowDMX is intended to help you quickly check the hardware is working, because it will almost always get through - but you shouldn't ever leave it set like that, as it will annoy everybody else!
could you expand on the concept of "equipment to sniff?" what would that be? does the RFR Handset display the stars?
thanx,
Marty
While the RFR is off, hold down the "More Softkeys" button, then switch on. This will boot you into the frequency changing mode. Then with the right wheel, you can change the frequency and it will give you a rating (the stars - 3 is best) for each of the available channels. Dont forget that if you change your settings on the handheld, you need to also change it on your console. Exit Eos/Ion, then hit the settings button, and then hit the RFR, and change to the appropriate settings.
hi Brian, thanks for the answer. Marty
hi all,
It is now several weeks since I wrote the original post. I am at the shop of one of my local shops and their head tech guy and I are trying to make this "star thing" work.
We using software v2 for the RFR. We are not getting anything when we do the "turn on with MORE SK" gag. It just goes into a Remote mode. We push all sorts of buttons and get no changes or stars. When we turn on the RFR, with base station off, in regular mode, it does tell us what channel we are using.
Any thoughts, anyone?
Hi Marty,
Unfortunately, in my experience, WDS steamrolls over everything, and I've not found "Frequency hopping" to help at all. If you have WDS running, the stars indicating traffic don't seem to be accurate. I worked on a show where the RFR would drop out (at least) several times during checkout, to the increasing aggravation of the electrics crew. Maybe not coincidentally the nearby 802.11 networks also were having a sudden high failure rate. When we stopping firing up the transmitters until after checkout was done, the remote was suddenly rock solid.
That's the bad news. The slightly better news is that the one show I worked wtih ShowDMX wasn't a problem at all. The ShowDMX in its default settings played very well with others, we didn't need to change anything. Kudos to City Theatrical for such a dramatic improvement.
Victor
ETC Northeast
It's not the MoreSK button (this is indeed remote boot) - it is the C button on the lower left corner.
There are a few different special modes - take a look in the manual:
http://www.etcconnect.com/docs/docs_downloads/manuals/Radio_Focus_Remote_Setup_Guide_RevC.pdf
-luke-
