Adjusting effect rate & size attributes on original command line
On the EOS, is there any way of adjusting the rate & size of an effect on the same command line that applies the effect to channels? I know that this can be done once the effect is running, but if I want to apply an effect on the fly and know that the default time / size will be too fast / too big for this instance of the effect then it would be really useful to be able to type something like: 1 Thru 10 Effect 50 Rate 25 Size 50. Perhaps this is possible, but I've not found a way to do it?!
Related to this, I always find getting to the effect instance screen after applying an effect (so that I can then adjust the rate / size of the effect) to be quite clunky. If I've applied 1 Thru 10 Effect 50 then I find I have to clear down the command line before hitting Effect again to bring up the running effect instance screen - is there a quicker way of bringing this screen up without clearing down the command line?
David
