Magic sheets
I am on a steep learning curve with Gio, but maybe trying to run before I can walk.
To bypass some of the command line entry and time taken to put channel numbers to physical devices I am trying to create a geographical map Magic Sheet. Success on a Mac OLE but when I save the xml file and load into the Gio I seem to have lost everything except the channel numbers. When I raise a channel a rectangle appears with its corner lopped off, with the line colour reflecting the intensity, but no lantern symbol.
 I can only assume the Gio doesn’t share the graphical information. Is there a way to transfer this or will I have to start a new map from scratch?
