Eos 2.9.1 show control syntax bug?
Hi all,
I was making a new event in the show control tab in eos and I noticed that there is no limit on how many times you can press some of the softkeys. Like if you press the softkey "Before Sunrise" there is no limit to how long it will show up on the command line. Not sure if this is supposed to be there or not. Here is a screenshot from nomad on windows 10:
