[BUG] Cue notes not working on magic sheet item
When setting an objects target to Cue, and manually specifying a specific cue to use, you can't access the cue's notes like you can when set to Cue - Active. Usually this is Text 1, and the magic sheet shows it as:
(Text 1)(Notes)
However with Cue specific target, it is instead:
(Text 1)
And going into live to see the magic sheet shows nothing.
