[Bug] Unable to change to user over 99
Hi All,
So found a bug in the user system, you are able to create users over 99, but can't change to them. When trying to change in the Blind setup window it produces a syntax error, same as if you Macro the change being:
User_ID Syntax Error
Trying to use the newer dropdown menu to change user doesn't result in an error, however it doesn't actually change, it just closes leaving you in the same user as before.
I know it's rare to have 99+ users, I was doing it more for organisation rather than actually for the numbers, but an error to warn about it would at least be nice.
Bug found on EOS 2.9.1 Nomad for Mac
