Sync lights to backing tracks with MIDI in DAW (Logic) on same Mac
Hello, I'm wanting to sync lights for my band using our Mac with ETC Nomad and the Gadget II. We play with a click and backing tracks in Logic.
Quick rundown: What we've been using is DMXis, which works as a plug-in in your DAW. You create a MIDI track and import said plug-in, create banks and presets for your lights with MIDI notes corresponding to each preset, then write the notes in the track. When you press play in Logic (or whatever DAW), the lights would switch to a that preset as the cursor passes over their corresponding MIDI note.
I now have ETC Nomad and the Gadget II with a 2 universe dongle that I am wanting to use. How could I make this happen? Ideally I want to run everything off of the same Mac. I've been seeing posts about MSC, OSC, MIDI Timecode, etc. But is there a way to make it work so that when we press play in Logic to start our click and backing tracks that the MIDI track plays as well and fires the presets for the lights?
Thank you all very much :)
