2.9.1 - Effect {Random Rate} softkey posts multiple entries on command line, {Random Rate} tile only posts one
2.9.1 release version:
In the Effects tab, the {Random Rate} softkey does not act the same as the {Random Rate} tile.
The {Random Rate} softkey will post "Random Rate" to the command line each time it is used, while the tile only posts it once no matter how many times you click on it.
-Todd
