[Bug] Macro set to target "Master Only" not executing on master
Hi All,
So I was setting up some macros designed to run on the master console only, as they require going into blind previews in default mode. However, if the user on the backup and master are the same, they will execute on the console that calls them. For example, when I then triggered the macro from the backup, the backup executed it, as it's screens changed and the masters did not.
I think this should instead work that the master will always be the one that runs the macro, no matter if the user number is the same, as it isn't targeting the user, but instead the device.
